Hello
I noticed today that the pressure sensor on my unit is not working, I am using an OpenTx radio with an ACCST D16 receiver working in F.Port Protocol, I am receiving all the telemetry sensors from both the Spirit and the ESC on my radio without any problem, but the Alt sensor value is only showing values between -0.4 and 0.4 meter.
i attach below a copy of the OpenTx flight log for inspection.
Kindly advice how to solve this problem.
[SOLVED] Spirit GT, Pressure Sensor not working
- Ahmad.Kassem
- Attachments
- T-Rex_500X-2021-07-19.csv
- T-Rex 500X OpenTx flight Log
- (939.49 KiB) Downloaded 137 times
- Ahmad.Kassem
Dear ZeXx86
Kindly update on this post
Sent from my SM-N976Q using Tapatalk
Thank you for the post. I will update when I have more details. We have to test all OpenTX versions.
- Ahmad.Kassem
Also in the fbl flight log, it showing zeros
- Ahmad.Kassem
Any update on this post?
josephbeard6
I'm having a similar issue, seeing Altitude sensor values less than 2, despite going 50 - 100 feet (15 - 30 meters) into the air. I'm a newbie to Spirit (but very pleased so far!), so it's quite possible I have something not set up correctly.
Model: Kraken 580
FBL: Spirit GT (Red)
Receiver: FrSky RX6R, running ACCESS 2.1.7 firmware, connected via F.Port.
Transmitter: FrSky Taranis X9D+ SE 2019 running OpenTX 2.3.14
Did I set it up wrong?
EDIT: Attaching a flight log
Model: Kraken 580
- Attachments
- Kraken_580-2021-08-01.csv
- (1.02 MiB) Downloaded 81 times
unfortunately I can't tell you F.Port connection will work correctly with ACCESS receiver. These are using F.Port 2 as far as I know.
We were testing only with F.Port version 1, so compatibility can't be guaranted yet.
Anyhow it should not affect what sensor is measuring.
We did several improvements in the upcoming firmware 3.3.2 (release in next week), so it might help you.
josephbeard6
This receiver lets me select in the options either S.Port, F.Port 1, or F.Port 2. I've got it set to F.Port 1 at the moment based on a remark I saw on the FrSky FPort page in the wiki:ZeXx86 wrote:unfortunately I can't tell you F.Port connection will work correctly with ACCESS receiver. These are using F.Port 2 as far as I know.
I'm still awaiting the ESC telemetry cable to test the other sensors. Otherwise, everything other than the altitude sensor seems to be working just fine.FrSky FPort wrote:Please note, Spirit GT has support for F.PORT 1. F.PORT 2 protocol will be fully supported soon too.
josephbeard6
I updated to Spirit 3.3.2 on my Spirit GT yesterday and then re-scanned for sensors. I now have a new sensor called GAlt which seems to be giving me altitude information. I'm not quite sure I believe the scale, exactly. For example, the second flight in the attached log has me going to 174.5 feet (53 meters) but, from my completely unscientific wild guess on the ground, I don't think I went much over 100 feet. But relative data is still useful to me.
Any advice for the best way to calibrate this?
- Attachments
- Kraken_580-2021-08-15.csv
- (1.07 MiB) Downloaded 86 times
