Rescue Normal works in reverse with new 3.3.1 integrtion
krm97
I just downloaded the new 3.3.1 Integration software and loaded it onto my Jeti 12 transmitter.
When I checked the setup, Rescue Normal works in reverse, I get negative pitch instead of positive and there is no way to reverse it. Even if you reverse the switch, the result is still the same, negative pitch in the normal upright position.
Gtamas
then your heli setup is wrong, probably all servos are reversed, or on the diagnostc tab you an see if any your channels in the transmitter is reversed, and you set up the heli with a fault in the first step.
i also have 3.3.1 with spirit RS, and DS16 transmitter, and everything works fine.
any of the recent updates will not cause rescue to work in reverse, if your previous firmware version was not 2.X or older.
If yes, then it is recommended to make Setup again, Setup Wizard will help a lot.
krm97
Thanks for the recommendation. I will try it.
