Version 1.1.0 released!
Version 1.1.0 was released!
It brings many new features and improvements:
  • JETI model integration - Support for real-time configuration with JETI transmitters! Check our instruction on the forum for more information.
  • Added Pitch Pump Booster - Very new function for simulating flybar-like collective behavior.
  • Improved vibration immunity - Resistency for low frequency vibrations was increased.
  • Updated vibration logging - New and more precise vibration logging for the flight log.
  • Better Spektrum compatibility - Support for DSMX mode for a transmitters capable of 22ms only.
  • Better Futaba S-BUS compatibility - Improved support for Futaba T8J transmitter.
  • EX Bus improvements - New implementation of EX Bus capable of sending telemetry data of the unit.
  • Various optimizations - Algorithms are even more optimized so they are significantly faster.
  • Smoother servo movements - Servo movements are even smoother with all single line receiver connections.
  • Expert settings - New expert settings helps with fine tuning process.
  • Keyboard control - Software usage can be very fast now! Thanks to new keyboard control.
  • Bank profile saving - Saving profiles for all available banks can be made with one click from now.
  • New and updated presets - New and updated helicopter presets are available in the wizard.
  • Fixed reconnect issue - Reconnect button in the software should work with all Windows configurations now.
  • Updated Wizard - Wizard in the software was updated to match latest needs.
  • BEC tester - Support for checking performance of the BEC directly in the software.
Changes from previous version 1.0.25 in your settings:
  • All settings from previous version are untouched. You do not need to re-configure anything.
You can download it from our web pages!
