[Bug] Tail servo pegs after
Posted: Sun 29. Aug 2021 15:28:05
Spirit GT, firmware 3.3.1 (F.Port)
Archer RS 2.1.6 (F.Port)
FrSky OpenTX latest OS.
560/760 tail servo
If I connect power to the heli with the transmitter off (or with the wrong model selected, etc) then, as expected, the spirit alerts me via servo movements that it doesn’t have a connection. However, if I then turn the transmitter on, I seem to have control again except that the tail servo is pegged to one side and doesn’t move much or doesn’t move at all. I don’t have full control of th tail servo when this happens. This issue is repeatable for me.
Once, one of the cyclic servos (1520/333) was also pegged causing a tip over tendency on spool up.
My current solution of course is to power down the heli and have the transmitter ready to go before powering on the heli again. But the FBL unit ought to recover nicely from no signal at startup to recovering signal.
560/760 tail servo
