Spirit 2 and 2S Lipo supply.
Crashpilot1977
are there problems with 2S Lipo battery supply directly on the Spirit 2? With me, the Nickservo is smoked out on the ground.
Best regards
Marek Bischof
swash23
I am using a 2s Lipo for several hundred flights on the Spirit 2 and the Spirit GT.
No problems so far.
latjo-k
Crashpilot1977 wrote:Hello,
Best regards
Marek Bischof
Hi
Spirit units is made for 3-15V and can deliver power to 5HV servos.Maybe your servo whas a low voltage
servo 4,5-6V or there whas something wrong whith the servo.
Latjo
Spirit is not doing anything to voltage you will feed to the servos.
So there should be technically no way how a FBL unit or receiver can damage the servo if you will set recommended frequency and neutral impulse.
