Throttle channel and Expo question
Tgalo
Two questions, in the diagnostic page my throttle bar doesn't move but the throttle works. I have a linier curve set. Also, can I add expo from the transmitter?
Thank you
10x
Has the throttle been assigned a channel?...Yes you can add expo to TX...
Tgalo
I have created a new model. Haven't gone into channel assign in my radio. Using Spektrum. On the diagnostic screen, it says "unassigned"
10x
You need to go into the general tab and receiver, Have you set up the receiver type yet?, Hit channel button and assign throttle to channel 1...
If this is a new setup it is best to use the wizzard to setup.....
Tgalo
Ahh yes, I see that now. But the throttle button is grayed out. I'm using a standard receiver and picked PWM.
you can't see Throttle channel with PWM connection, because throttle signal is not coming to the Spirit unit at all.
Throttle is connected to your ESC, but unit can't know the signal value with this connection.
In other words you do not have to change anything regarding throttle in the Spirit unit. Only your radio is controlling it.
