info about GT altitude
urgno
hello
is possible to see what altitude is detected from spirit GT
when doing tests on bench ?
thank you
HeliMLM
there is a minimum of vibration necessary so the GT/GTR is detecting the heli as flying (i.e. mechanics running *without* all blades worked for me)... but then you can go into diagnostics & advances logging features. if you log the altitude there you could see it (will be 0 unless you move it around a bit... mine showed 0 on bench and ~1m when lifted above bench).
cheers
Michael
urgno
i was hoping there was a real time indication like in geolink status screen
