Tail Drift
Gregster
Recently swapping out from VBar Neo to Jeti and Spirit RS..
Installed spirit int a Goblin 570 and have initially run a couple of test flights to verify.
I have noticed a drift on the tail of the machine that is not holding...without adjusting i am able to change the drift between a drift to the left or right by altering the tail rod length but cannot stop the drift.
could it be that the tail blades are the incorrect for the machine or have i missed something in the Gyro gain setting ???
thanks for help
HeliMLM
what is the value for tail gain? and what is the rudder common gain set at? maybe you could post your settings file?
cheers
Michael
it seems that you have not set Tail Gain and the gyro is in Normal (Rate) mode.
Please set Gain to around 50% then all should be good.
Gregster
I think that may have solved it - thanks guys. total brain block on the new radio
