Governor RPM setting
Gregster
Newbie question, spirit GTR running with Jeti...Hobbywing platinum ESC with RPM telemetry working...
I read I think somewhere that my banks and flight modes could do so by setting an actual RPM a level..I am not seeing this in settings and have only the typical flat line percentages for throttle output to play with..
Locking into a specific RPM a target would be a lot more sensible if it’s available ?
you can set maximum head speed in the Spirit Governor.
Then by setting up flat throttle curve you can set any RPM. You can see Requested and Current RPM in the Governor window.
