Geolink angles appear off after a crash
Aquaaddict
Hi Thomas,
Following a crash (in which the geolink case did get broken so it received some impact), the Geolink appears ok in the Spirit software except both the X and Y values for Mounting Inclination are off by 10-12 degrees when level (confirmed by swapping with another Geolink in the same physical position). Can this be recalibrated or repaired? There is no apparent physical damage to the components but I wonder if the shock has damaged the XY sensor internally?
Ants
I believe your GeoLink can be fully fixed. Repair could cost around 3-10 USD depending on what has to be replaced.
You can ship it to us. A note with your email address might be enough.
Aquaaddict
ZeXx86 wrote:Hi,
Amazing, thank you Thomas! This is one of the (many) reasons I only use Spirit on all my helis and recommend it to everyone :)
Will get it into the post to you...
