[SOLVED] swash is tilting after initialisation
Posted: Sat 28. Feb 2015 11:24:22
sometimes directly after plugging the battery and initialisation, swash is (very) slowly tilting to the right while heli is still on the ground.
This isn't an issue with normal flying, but rescue isn't that precice.
Rescue is tilted to the same direction the swash was tilting after initialisation.
During the flight, it may become better.
observations on the bench.
It isn't 100% reproducible, but when it happens, then the following could be observed:
1.) swash is very slowly tilting to the right (always the same direction)
2.) you can level the swash with aileron-input on the TX, but as soon as you leave it alone it starts again tilting to the right.
3.) When hitting rescue switch then:
- swash is slightly tilted to the right.
- after releasing the switch swash is prefect level.
- then slowly starts again tilting.
4.) power-cycle the unit, and the issue is gone. Swash is level and stays there "forever".
Any idea, how we can nail down this issue?
- I would exclude the TX. Sticks are perfectly zero, which can be veryfied in Diagnostic-Tab of Spirit-software.
- due to antispark-resistor and capacitors in the ESC it may be that power isn't instantly at full voltage.
- maybe I am moving the heli a little, while plugging battery.
- maybe some temperature drift of the gyro-sensor?
Greetings
Manfred
Greetings
Manfred
