[SOLVED] Spirit GTR, FW 3.3.3 - Throttle locked on channel 1
sacha
Hello Spirit Support
I've upgraded to the version 3.3.3, also installed the Spirit Software 3.3.3 (Link from this forum)
On 3.3.2 i had changed the throttle to channel 7.
After upgrading to 3.3.3, it switched back to channel 1 !
Even when i change it back to channel 7 and save to the unit, it's not saved !
After a power cycle it is still switched back to channel 1.
Thanks for your help.
Sacha
there should be no difference in channels between versions.
What receiver protocol are you using?
With spirit RS and GTR - Jeti it should be always at channel 1.
sacha
Jeti EX Bus
In my setup i need throttle on channel 7. On 3.3.2 i was able to change it to channel 7 after save to the unit.
After upgrading to 3.3.3 my change will not be saved. After a powercycle throttle is still on channel 1.
I am afraid but from version 3.3.3 Throttle channel will remain always at Channel 1.
This is because in JETI radios there is profile for Spirit which also has channel set and all remaining base channels are fixed.
So in this way it will always work out of the box with no additional settings.
Tomorrow version 3.3.3 will be oficially released with all release notes.
We recommend to set Spirit model type in the JETI model profile and it will work with no possibility to make mistake.
By default all channels can be configured in JETI radio but with Spirit RS and GTR it is not needed anymore.
sacha
Phu, ok will do so.
For safty, please add this important information in bold to the changelog.
In my case it silently changed my configured channel 7 to channel 1, after upgrading to 3.3.3
Sacha
Yes, it will be written in the changelog with bold.
sacha
Many thanks for your fast support !!
