[SOLVED] Spirit FBL & Futaba T8J
Ravp66
I'm going to buy a FBL Spirit System. In the last update note it was written that operating with Futaba T8J was corrected. I have receiver R2008SB. Does Spirit System works properly with Futaba T8J? Are all the functions of apparatus available? I'm going to connect the system via S-BUS adapter. My both helis has servo KST inside.
greetings
Rafał
yes, all works correctly. Previously it worked too, but now it is even better.
Thanks for your interest!
N3M0
ZeXx86 .. In what way does it work better? What were the limitations before the update? Does the T10J have these same improvements?
There is minor change in data stream processing from these transmitters so it can work little bit better. But mostly there will be no observable difference. It is possible, that with T10J it is better too.
