Microspirit stabilisation problem
Posted: Mon 08. Nov 2021 17:17:12
I have run into issues with my Microspirit I do not understand and so I hope that experts are able to help me:
I was using the System in an Oxy 2 without issues for hundreds of flights. Recently I decided to change to 4S. Since I had batteries first I tried higher headspeed during preparation without problems. But when I changed the whole setup by installing the new pinion a weird problem emerged.
After 2 or 3 flights with high headspeed (by calculation it should be around 5000-6000) a wobble on the main rotorhead appeared in some flight situations and got worse. I tried to change the head gain which made things slightly better for a short period but it got worse despite the fact that I lowered the gain to the 20% minimum which I now have running.
The only thing I have discovered this far that is helping is lowering the headspeed. Which I did to about 4500 rpm. But now this problem (that was not observeable before at all) also exists when I use 3S Batteries with low headspeed (But mainly during Funnels). Does anyone have an Idea what could be the cause of this problem (The wobble gets pretty strong at times and i fear for the heli which is why I need to resolve this problem fast)? Since it is getting worse I guess a mechanical problem would be possible but I did not change the system and everything should be set up properly (I did however have some issues with rotor-Blade tracking but I think changing the DFC arms resolved this problem).
Could it be that the Microspirit system is somehow faulty? How can this whobble, without strong correlation to the head gain, appear because of "high" rpm whilst becoming worse so it now appears even on lower headspeeds. Would it be an option to send the Microspirit to the producer for a checkup or should I try making a new setup or changing specs first?
I would be thankful for any help. What would you suggest in such a situation?
Greetings
Greetings
