Wizard setup
KaltBaron20
Question for support. Once the gyro setup is completed via wizard, to achieve maximum pitch of 10 degrees and minimum of -1degrees....will adjustments to linkages effect the 6 degrees geometry setup
Yes, it will affect everything and is not recommended.
Instead you should use settings in your radio to set pitch from +/- 10° to 10/-1°. So adjusting pitch curve is the only correct solution.
KaltBaron20
Wow..good I asked. As I fly scale I prefer a linear curve -1 or 0 to 10 degrees. Thanks for the reply.ZeXx86 wrote:Yes, it will affect everything and is not recommended.
KaltBaron20
So there is no way a linear pitch curve from 0-10 and linear throttle curve 0 -100 can be achieved via the spirit 2 system ?? Is that correct ??KaltBaron20 wrote:Wow..good I asked. As I fly scale I prefer a linear curve -1 or 0 to 10 degrees. Thanks for the reply.ZeXx86 wrote:Yes, it will affect everything and is not recommended.
Yes, there is way that I described in the previous post.
Simply set pitch curve from 0 - 100% to achieve pitch range from 0° to 10° - instead of -100% to 100% for +/- 10°.
But initially mechanics must be set for full range. So that when servos are in the center position, there must be 0° between main blades.
Any other settings will lead to imprecision. This is common for all FBL units.
