I recently updated my Jeti Transmitter with version 3.33 Integration.
All of my heli's were working fine using a 6 meter level for auto bailout.
When I checked to see what it was in the Spirit Program running on the Jeti, it was only 1 meter.
It did not matter whether I used 1 meter of 6 meters, the auto bailout was activated at about 7-8 meters.
What changes do I need to make to get the autobailout working properly again?
All the best,
Ken
Auto Bailout Altitude Setting not working
Hello Ken
pls read the release notes of 3.3.3 carefully... there is a new process of activation of auto rescue. the height is set at the height you *activate* auto rescue... the parameter in the setting is not for auto rescue height, but for adjustment for inverted flight ("altitude rotor compensation" - normal/inverted will produce different air pressure for the sensor). so what you have changed only will affect auto rescue in inverted flight - pls check carefully if this is OK.
if your Spirit integration still says "rescue height" => pls double check if your integration files have been overwritten in Jeti and all your Spirit units are on 3.3.3
cheers
Michael
Michael
