Feature wish: split differently the integration scripts
offer.shmuely
The integration scripts are very useful (I use edgeTx scripts)
Even the splitting are very handy, as we do not need pass too many pages to perform the task we need.
it even easier, now that openTx/edgeTx show them in the first page, and we can run them in one click (no more long-press --> Execute)
what I like to suggest to improve, is the re-splitting the values as script for "first setup" and "field changes"
as I will never reverse the servo on the filed, nor change the rate of the servo, and yet, I still need pass this screens (with real fear), each time I like to change the cyclic-gain
personally, I do all the first setup on a computer, and on filed to small adjustments all the time.
offer.shmuely
Hello again
Is there a chance to change this layout of parameters on the scripts?
it is possible one day we will change it.
Unfortunately there is no time to do it now at the moment. In any case no parameter will change on its own, so no special care must be taken until you will really modify some value (and save it).
On the other hand you can assign many parameters to a free channels and tune them in a real time. With this you do not have to enter the integration menu and you can find optimal value for all of them.
offer.shmuely
I love the integration script
And it was a good decision to split it to more that one script ! (comparing to ikon)
It just that the parameters is is not organized correctly
There are parameters in advance, that are totally not advanced
The tuning on field should not be together with one-time-setup
The log viewer should be more compact with more info
And there is a place for a widget (not tools script) that will show if there is issues in the log that worth opening the log viewer script for further investigation (maybe something with a flag, or traffic light?)
There are a lot that can be improved, so less flyers will enjoy the spirit, instead of giving up, and move to the v-bar touch, i also can help if it going to the correct direction.
The edgeTx do today a lot of fancy stuff
Take a loot at a log viewer I wrote recently
https://github.com/offer-shmuely/edgetx ... ripts/wiki
