I set my spirit governor to 2000RPM.
In reality, the telemetry called 2300RPM.
So I took out my Tachometer and it read also 2300. Btw, this was on 67% throttle (flat curve)
Then,
I tried to reduce the governor setting to 1800rpm, just to see what happens.
The actual RPM eas even higher than before.
It was 2360rpm.
Motor is a scorpion 4525 10 pole.
I set the sensing devider to 5.
ESC range 1100-1940.
Gear ratio 10.1.
What the deal ?
Thanks in advance.
Sent from my Redmi Note 8 Pro using Tapatalk
Wrong output RPM GT Governor + HW 200A v4.1
please make sure that Spirit Governor is enabled in all banks (if used).
And also that Governor in the ESC is really turned off and there is no spoolup procedure enabled that could interfere with Spirit Governor spoolup procedure.
This is dependent on mode that is configured in your ESC.
