I had a Castle Edge 160 ESC on my Goblin Raw in which the governor worked flawlessly. I did not use the Spirit GT governor.
I recently switched to a Hobbywing 130A HV ESC and tried using the Spirit Governor. The Spirit Governor will not activate because it wants a throttle reading above 50%. This is very unfortunate because at 42% throttle reading my RPM's are 2000rpm. Why would you ever set the governor activation at 50%?????????????????? It has nothing to do with the RPM readings on the heli. It might be somewhat predictive of RPM's but not a very accurate indicator.
Can you fix this issue?????
All the best,
Ken
Governor Activation Issues
Hi
if you configure the Spirit Gov, you will i.e. set your max. Headspeed value to i.e. 2.500rpms.... then 50% will be only 1.250rpms (it is always the percentage of the Max.Headspeed parameter then). what headspeeds do you like to configure?
cheers
Michael
Michael
