Spektrum integration
ExCCHP
I have the Spirit GT with the GeoLink Module. Using a Spektrum AR6610T receiver and an NX8 transmitter.
Everything is installed, configured and working properly. I have the latest update on my transmitter 3.06.02. The Spirit unit is also updated to lasted 3.3.3.
I can not get the Spektrum's integration to work. Manual says with transmitter turned on and on the main screen scroll right till you see a blank screen. I don't get a blank screen. Last screen is "VARIO"
ExCCHP
I got it to work yeah!!
The instruction are not clear. It says to scroll right to blank screen, then hold stick inputs for 2 seconds.
On my NX8, need to scroll right to last screen. Then while holding stick inputs, rudder right, aileron left, scroll right one more screen. This will also work from main screen while holding stick inputs, scroll right to the end. Spirit integration will appear.
you are right. NX series have this different from older radios. We have to update the guide.
Thank you!
