Channel 1 and 3 Reversed for proper orientation
Uplate
Cannot quite figure this out.
450L
Aileron reversed in Radio
If I plug the servos in according to 120 swash setup, pitch does not move all three servos as it should. It acts more like and elevator.
Getting things moving in the right direction. Elevator stays on Channel 2. I have to swap servos 1 and 3 to get things moving correctly.
So now at sub trim settings, I go to trim channel 1 and aileron moves. So it is naturally swapped there.
Everything looks good in the Diagnostic window, with the exception of the aileron graph direction as it is swapped in radio. Swash moves correctly though.
Not sure why servos 1 and 3 to not act correctly when plugged in per manual/setup.
In layout, Pitch is mapped to channel 6 and throttle is mapped to channel 1 per the SRXL single satellite instructions.
Uplate
Coming from a Beastx, I did not have the change anything in Radio. Initially plugged Spirit in the same way as BX.
Swash in TX is set to normal.
All channel default settings are default.
Should I change RX port assignments in Spektrum Tx?
Just want to make sure my configuration is proper Spirit to do its magic.
Thank you.
10x
You need to follow the manual/wizzard at every step and pay notice to page 6/10 of the wizzard for servo reversal...
Uplate
Thank you 10x! That was it. As a new guy I thought those were for reversing servo directions and did not understand the fine print.
I reversed Channel 1 and 3 at page 6, and then took off the Aileron Reverse servo the TX and all is working well.
Again, thanks for taking the time to help.
10x
Just go back to diagnostics window and double check all is right there. If it is, its ok.
