JITTER WITH FUTABA RECEIVER
JaeIn Go
Hello, guys.
the last time, I posted ESC, servo jitter in my goblin raw 700.
When Fast pirouette and flip I could observe servo jitter and ESC shut down.
As a result, I solved the jitter by changing futaba receiver( R7008sb to R2008sb)
first, I checked all servo lines and ESC lines. it's cleaned.
Second, I connected ESC signal line to the receiver 3 channel port directly.
at this time, ESC shut down disappeared.
Third, I moved the receiver antenna at tail boom.
above all, Cyclic servo jitter still remained.
finally, I changed receiver R7008sb to R2008sb.
all jitter vanished.
I don't know why jitter vanished.
Because goblin raw flying very well with other flybarless system(neuron).
MY goblin raw 700 setting.
Spirit GT,
hobbywing 200a SBEC 7.6V, store governer mode, Xnova motor,
MKS X8 servo cyclic xpert R1T tail, futaba 16sz, R7008sb receiver s-bus.(now R2008SB)
additionally,
I installed 4 spirit GT in goblin raw KSE, 700, Kraken 580, old goblin 700.
there was servo jitter and ESC shut down 3 spirit GT with R7008sb, R7003sb.
I solved by changing receiver cable at KSE and changing receiver antenna position at Kraken 580.
only one was fine with 6303sb in old goblin 700.
please try to connect R7008SB to S.BUS, not S.BUS2. This could help.
R2008SB is not telemetry receiver, while the others are. So telemetry is always turned off there.
