Spwktrum tm1100 + Spirit fbl
riodoro86
I'm using the spirit fbl in combination with two Spektrum satellites.
I was able to bind the tm1100 and the two satellites by bringing the satellites and the tm1100 into bind mode at the same time. So far so good.
After removing the bind plug and binding again it seems that only the tm1100 has bound correct. The satellites are flashing very slightly and my inputs From the transmitter have only short effect and then it resets.
DoesAnyone have any experience with my Problem?
it seems as the unit is underpowered. Can you describe your connection (especially where is connected power supply/BEC)?
riodoro86
this was also my first thought but i have connected throttle to the aux port and the bec Form my hobbywing via y-cable to the rud port. So i guess power should be OK...
Ah, and how is connected TM1100 module?
Maybe photo would be the best if possible.
riodoro86
Right now it is connected directly to channel 4 for testing only (only + and - no signal). My idea was to connect it later by y-wire to one of the channels. I'll make a sketch and upload it tomorrow.
Thanks so far!
riodoro86
i uploaded my wiring
linux-user
Have you tried to simplify your wiring for testing purpose?
i.e.
- remove the second BEC or
- remove the second satellite or
- remove the throttle
The idea is to let it running with the least possible configuration to exclude things.
Indeed, I recommend to try connecting only necessary stuff together.
riodoro86
I'll try and report afterwards.
Thanks so far!
riodoro86
ok, i tested each possible combination. no sucess :(
The only thing left i can imagine is that the tm1100 has problems with non spektrum satellites. I'm using orange dsmx satellites. Unfortunatelly i have no original one available for testin.
