Autorotation Hobbywing Spirit GT
nichtdiemama
Hello
I have a Spirit GT actual FW and a HW Platinum 120 V4 ESC actual FW. I set up a switch in the transmitter to turn off the motor (0%), one switch for the speed (60%,70%,85%) and one switch to change to 12% to activate the autorotation.
The Governor works fine and I can switch the speed and turn off the motor.
But when I activate the autorotation (12%) the motor keeps running on a low RPM. If I deactivate the autorotation within 3s (Auto Bailout) the motor spools up quit slow.
I set up the ESC like mentioned in the manual with EXT. Gov and FW disabled.
What do I have to do to get the autorotation working normal?
PS: I tried to reduce the 12% only under 5% the motor stops but spools up slow like it does wit 0%.
