Coll pitch
latjo-k
Hello
I have a small issue,i have 3 flightmodes norm 1 and 2 -100-100 coll pitch on all 3 banks on a Spirit RS.
When i goes from norm to 1 the pitch changes(all 3 servos)toward +1deg,and from 1 to 2 the pitch goes back to the same value as norm.
This happens no matter what the pitch value are from TX,the heli on the bench.In diagnostic tab the pitch value is constant,and
in limits tab i have the same pitchlimit for all 3 banks.No stabi or antigravity activated.If i open throttle window or
the advace expert settings and changes FM(banks) the servos dont moves?
The servos changes values allso whith no computer connected.Anyone have an answer to this???
In real flight it is barley notisable as the RPM changes.
mvh
Lars
Can you save the settings from the unit to the attachment? All banks.
Don't have banks linked to flight mode and won't there be different pitch settings in flight modes?
latjo-k
Hi
Solved,antigravity bank1 whas set to10.Im shure i set it to zero in all banks when i did the first setup.
Thanks anyway.
mvh
Lars
