Save radio connection from Spektrum NX8 to Microspirit
Diogenes
Could someone please describe how I can achieve the save connection of the title. Thus far I was not able to create one using those and comparable satellites: https://www.modell-hubschrauber.at/Send ... 29156.html
I always have been having motor outages and now I bought a completely new Oxy 2 mechanic. I gotta get this right this time. I use 2 of the same types of satellites on my v-bar in the goblin 380 and since I use 2 of them I had no problems there for approximately 200+ Flights. Will an original Spektrum satellite do the trick? They are hard to come by at the moment which is the reason for me using those alternatives. In winter I could not fly 2 flights with out connection losses in the logs. I even bought a spartan vortex to check if it is the microspirit but I had the same problem. It is getting really frustrating and expensive. Last season I had approximately 50 flights with the setup without a problem.
Would for example this satellite work better?: https://www.modell-hubschrauber.at/Send ... 27664.html
