GeoLink
MegaHz
When setting up Geolink, and using Spirit Setting program (running WIN10) I lost connection to Geolink even though the blue LED is lit solid. I can access all settings but under "General" setting when I click Geolink - Settings, only "Info" appears but all other options are faded (not accessible) - module, map, aid. I can not get any response whatsoever. It is not communicating.......
And when I leave program window still open, on helicopter power OFF and power back ON, new program window opens and says "your receiver setting has changed"! It went from SRXL2 to SRXL/SUMD. And I didn't perform any changes, it just happened on it's own. It changed protocol itself! Radio has no response now obviously.
I am sorry, but this problem (protocol change on its own) happened once before. This event just confirms my previous theory that there is a bug. I just managed to replicate this problem. Not happy with this.
it seems you could have old integration files in your radio.
Are you using JETI or OpenTX integration?
If yes, then the problem could be there. Please note it is also not recommended to open software and integration at the same time.
