Stability question
Umoxx
Hi just wondering if it's possible to fly inverted or do loops and rolls while in stability mode?
At the moment I'm not able to go past a certain angle ?
Is there a setting I can increase to allow me to go inverted and hover while the unit helps to stabilise me so I can learn inverted orientation.
Cheers
djhandz
Hi its not possible to loop or roll because as you say it wont let you go past a certain angle unless there is setting i dont kno about. You can use inverted stabilty to help learn inverted. you need to get the heli inverted before activating stabilty hope this helps
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
For learning loops and similar manouvers it is best to use normal flying mode as stabilisation can't teach you doing this properly.
In case of any trouble you can simply activate rescue mode, which will help you immediately.
Umoxx
Ok that's fine I can get into inverted fine but loose my way after a little so if I can go into stability mode and it will help hold it then that's cool cheers.
In the future releases, we will add new stabilisation modes, so it can help you even more.
