Jeti Hard Deck SetUp
Posted: Fri 01. Apr 2022 21:43:55
by kcasser
I had this all figured out and working fine until I switched my Rescue function from Gyro to an Assigned Switch (Ch. 7). Now, my Rescue works when Switch SL is pressed, but with Hard Deck mode activated, the rotor spools up but the pitch does nothing unless I simultaneously press SL. Very strange. I've tried everything I can think of. Can anyone point me to a proper setup or could you take a look at my settings and find my error?
Jeti DS-16, Spirit FBL.
Rescue Flight Mode enabled
Function 7 - Rescue - SL
Function 8 - Hard Deck - L1 but it doesn't seem to change anything when I change the switch configuration for either of these Functions.
Telemetry Controls:
Mx1 MALTI:Red. altit
X< 19.5
Duration 0.3 sec
Default 0% (0) Switch (unassigned)
Logical Switches
L1 Hard Deck SC AND Mx1
L2 Rescue SL OR L1
L3 Disable SG AND L2 (to disable the Hard Deck and Rescue when in Autorotation
So, pressing SL puts me into full Stabi Rescue mode - no problem.
Flipping SG for Autorotation disables Hard Deck & Rescue and I can autorotate - no problem.
But, activating SC and being below the Hard Deck altitude threshold causes the rotor to spool up (properly), but does not increase the pitch (which it should do just like in regular Rescue)
any ideas??
Thank you!
Re: Jeti Hard Deck SetUp
Posted: Sat 02. Apr 2022 17:02:28
by kcasser
Problem solved!!! I deleted Function 8 (Hard Deck), and changed the switch assignment for Function 7 (Rescue) to L2. Works great.
