GTR changes throttle channel
Gobbi
After the last update to 3.3.3 i have a problem.
Every time i switch the bank, the throttle chanel changes from 4 to 1.
I have the pitch on chanel 1.
Does anyone know the reason?
this is because for JETI throttle channel should be at 1.
When you update JETI radio to the latest firmware and set model type to Spirit, then it will automatically assign it to channel 1 too.
This is also default JETI mapping. For making it clear and easy for pilots it is hard assigned to 1 for Throttle. It is same for other base channels as there is no reason to change it.
