Advanced Flight Viewer Question
tkosier
After a single six minute flight, when using the Advanced Flight Viewer, I get 5 logs, each being about 1 min 20 seconds long. Is there a way to get a single log of 6 minutes?
My Spirit/Jeti12DS records a single log of 6 minutes.
Thanks Thomas
flight logs are recorded based on vibration level. If it is over 4% it starts recording.
Only in case your model has super low vibration level it might cause such issue.
Can you verify what level you can see during flight?
I guess you are trying with blades on in a real flight.
tkosier
Thank you for responding
Appears my issue was too much vibration. Was using the log to follow up on some odd flight behavior. The logs revealed a vibration level of 80 magnitude! Replaced a bad bearing, rebalanced blades and tried again. On the bench with no main or tail blades, I ran a three minute test. The vibration magnitude was 16 magnitude and the entire run was recorded properly. Installed blades and ran a 6 minute hover in my front yard. The entire six minutes was recorded in one log. The vibration during the hover was recorded at 50 magnitude. All other parameters were recorded perfectly and identical to the log that was recorded by the Transmitter.
Thomas
