[SOLVED] Spirit GT rescue mode problem
AlexAusTelfs
Hi Folks,
since update to 3.3 rescue mode is not working properly. After activation heli is not climbing vertical but moves very fast to the right.
I am using GEO Link
Any hints please ?
Thx
Alex
very likely this is because you are activating some GeoLink function at the same time too.
There was no change in rescue in version 3.3 so I think it will be some configuration issue.
What will happen when you engage the rescue at the ground before flight?
Can you verify that when engaging Rescue mode, then there is no other active function - this can be visible in the Diagnostic tab.
AlexAusTelfs
Hi Thomas,
you where right. I forgot one channel after "optimization" and Geolink mixed in during rescue. Now everything is *perfect* again.
Thank you very much. OUTSTANDING service as always :-) :-).
Galuwen
