Lua-Script for OpenTx/EdgeTx diagnosis direction not correct
Following problem, in the Spirit GT the diagnostic tab all channels are working all in the right directions for example elevator down and elevator up, all ok -
In the diagnostic.lua all inputs are working fine (direction), however the direction of the elevator channel is wrong !
elevator up is elevator down and elevator down is elevator up - as said in Spirit-Settings all directions are right !
The programming of the script is probably wrong here -
For information, that was the only channel which must be inverted in the transmitter -
But when I think here is mabe the direction wrong and it must the channel inverted then I have possibly an problem -
If only the directions of the inputs of the transmitter are queried here, then that is simply not correct - it would be best to correct the error or simply not make this Lua script available at all, because it's just not right-
