Return to Home - set altitude
jjuk
How can I set the RTH altitude?
tzirancamaro
I also request information about how to adjust the altitude during RTH
Last Sunday this function saved my helicopter, thank you very much for that
jjuk
The problem I had was after changing from rescue to RTH, the heli lost loads of height and hit a tree.
presently it is not possible to set altitude for RTH, but it will be added.
At the moment you can combine Altitude Limit and RTH. For Altitude Limit you can set minimum to for example 40 meters.
jjuk
Should the max also be set to 40 metres?
