Nitro governor response to loosing rpm signal
Posted: Mon 23. May 2022 15:30:21
by pss999
Please can you make the nitro governor have a separate speed input channel, and default to the throttle curve if it looses the magnet signal.
Currently, if the gyro cannot read the rpm, it assumes 0rpm, and immediately goes to full throttle. This is both very scary, and very dangerous.
Please can the governor work like most other Nitro governors, so that it only engages when the rpm is above a certain trigger level, and the rpm is set by an independent channel.
Spirit GT, with Sprit RPM sensor.
Peter.
