FW 3.4 Channel Direct asigantion not work with Futaba Sbus
Dr.Fleming
FW 3.4 Channel Direct asignation not work with Futaba Sbus, and missing Anty gravity mode on channel list. :cry:
it works with all radios, there is no difference for unit what radio or receiver you are using until you have enough channels.
It mean that something is configured incorrectly. We will finish our manual to make it more clear in following days.
You can attach your configuration so I can check it.
Dr.Fleming
Thanks for quick answer, also I see on the channel windows,the green moves when I activate the Rescue normal,
but nothing happen, I try disconnecting the Stabi, but the same. But as usually works wit Stabi Funktion :roll:
ZeXx86 wrote:Hello,
You have to set Selected by Channel in the Stabi tab as Function.
Was problem resolved by setting Function to Selected by Channel?
