[SOLVED] no connection to PC or bluetooth after 3.4.0 update
rotorhead51
Hi Tomas
I am hoping you can help me with a strange issue after updating to 3.4.0, I was at the field today and connected with my phone to make changes to my nitro gov., noticing that I didn't have my radio on, I turned on my radio to check my diagnostic page and lost connection after turning on my radio. when I got home I tried using my PC and USB connector and it does not recognize my Spirit GT anymore (with my radio turned on). strange thing is, if I power up my GT unit without my radio on it recognizes the GT and I can make changes.
both software and GT unit is showing 3.4.0.
I tried re-flashing firmware and even recovery mode but it will not connect when my radio is on!
no problem yesterday when I initially flashed the update thru my PC, I immediately tried connecting with my android phone and it worked perfectly, with the radio on.
any thoughts as to what I should do next?
radio is Futaba 18SZ with R7008SB receiver.
have you enabled Kontronik Jive Pro, Kosmik telemetry?
rotorhead51
Yes, telemetry has been selected
I wanted to check my headspeed as I was flying.
Very likely you wanted to select TelMe telemetry option. Because Kontronik Jive Pro & Kosmik is old and deprecated option. And behavior you are describing is correct actually. See instruction when you select it or in the guide.
rotorhead51
Good to know, thank you for the quick response Tomas.
I will make the change.
BTW, my nitro gov. is starting to work the way I want, after lowering the holding limit % and increasing the main gain the head speed is holding just fine.
not sure if I would get this kind of customer service from any other manufacturer, your customer service is second to none!
