Whats new with GeoLink V2
Dr.Fleming
Whats new with GeoLink V2 !? :ugeek:
urgno
here you will find the features and pictures ;)
https://store.spirit-system.com/en/acce ... olink.html
Dr.Fleming
But I like to know how the Laser works, I supose that is facing down, also installing on a boom
will be a problem ! The point is, if I must order the GeoLink Holder or not.
sacha
I think that we have to drill a little hole into the geolink plattform.
So the laser has a plain sight downwards.
Sacha
urgno
Dr.Fleming
Yep, but if you installed on the boom ! :roll: ( It's wider !)
sacha wrote:I think that we have to drill a little hole into the geolink plattform.
Sacha
if you use our GeoLink Holder then it will work just well with no modification. However Laser usage is optional, so if it is covered in some model it is not a problem.
What is new?
Basically everything. All components are new and is based on the latest technology. It has much more processing power and available memory. So it can do much more things.
Now it is only dependent on firmware, because nearly anything is possible with this module. We plan to add many interesting features with each update, because it is simply possible.
Dr.Fleming
Ok will see, but I like to use the Laser, specially for Autolanding as a Failsafe will be great.
I order few Geo's on Backorder, when you expect ready for sent? :mrgreen:
I'm not sure to order one more Geo Link Holder :|
ZeXx86 wrote:Hello,
What is new?
sacha
I also ordered a few units. Can't wait to receive it ;-)
nichtdiemama
If the new geolink is so powerful how would it be with an failsafe autorotation. If failsafe aktive then negative pitch and shortly before the ground positive.
