Master Mezon does not intialize when connected to the Spirit
ChrisTTian667
Hey,
I am using a Jeti Ds14 with RSat2 connected to the Spirit via UDI. The ExPort of the Rsat is connected to the Master Mezon 120. Since i try to connect the Mezon through the Aux Port it is not initializing. When i try another receiver (R8) and connect the esc via normal out (pin1) everything works as expected.
Is there any known issue, why the mezon is not initializing when connected through aux port of The Spirit.
I tested the aux port with a jeti box. There is a signal between 0,997 and 1,997ms. Which should be ok.
I assume, that the Spirit is sending a weired signal while initializing?!
Can someone help me?
Cheers, Chris
Triabolo|Kosmik 200|XNOVA 4530 XTS|MKS 960/990|Spirit Pro|REX7
Diabolo BE|Kosmik 200|XNOVA 50XX Tareq|REX3
ChrisTTian667
fixed it for now by using another rx (R8 EX instead of RSAT2). I will wait for the new jeti receivers and give it another try, cause i am unable to use bank switching right now.
In an other forums i read, that i should decrease the throtthle range. I tried it but couldn get it to work. The range i measured with jeti box seems equal to the range i get with the standard R8 rx. In my old helicopter i use the BD3SX in combination with the Master Mezon working fine, so it seems to be an other interpretation of the signal by the spirit?
you have to assign Throttle function to Channel 1 in the channel assignment in the software.
Then it should work.
If not, then there is only different range, so in this case you have to recalibrace your ESC.
