[ Version 3.4.1 released! ]
New version 3.4.1 released!
  • Updated GeoLink Altitude Limit:
    • Altitude Limit has configurable triggering Altitude in flight.
    • Triggering Altitude is set by altitude from moment when the function is activated.
    • Behavior is similar to Rescue (Automatic) from Spirit GT/GTR.
    • When model will drop under configured altitude level, it will automatically engage rescue for 1.5 seconds.
    • Supported with GeoLink v1 and v2.
  • Updated GeoLink Return to Home:
    • Hands-Free Flight when function is engaged.
    • Once activated model will additionally maintain altitude configured by Return Altitude parameter.
    • Model will start moving to Home position but at the same time will achieve desired altitude.
  • Updated GeoLink Geo-Fence function:
    • When Geo-Fence is breached model will additionally maintain altitude configured by Return Altitude parameter.
    • Model will start moving to the center of geo-fence area but at the same time will achieve desired altitude.
  • New parameter GeoLink - Return Altitude:
    • New parameter for maintaining configured altitude when a GeoLink function is activated by a switch.
    • Used by Return to Home and Geo-Fence functions.
    • If configured to zero, then parameter is disabled.
    • Value above 25m is recommended.
  • JETI telemetry update:
    • Telemetry variable S GPS Sat is updated also when ESC telemetry is unused.
  • Anti-Gravity feature:
    • Anti-Gravity feature is working also for Stabi functions.
  • New HobbyWing Platinum v5 ESC telemetry:
    • Full support for HobbyWing Platinum v5 ESC telemetry.
    • See wiring and settings at the Wiki page.
  • Spirit Settings - Setup Wizard:
    • Goblin 500 - 580 preset was updated to support the latest SAB Goblin models.
    • Goblin 700 - 800 preset was updated to support the latest SAB Goblin models.
Update for the Spirit units, JETI integration is available in our Download section.
WARNING: Please be aware that GeoLink's function Altitude Limit behavior has changed and Return Altitude parameter need to be configured.
Update for Wifi-Link and for JETI integration is available for download from our download section :)
