Geolink, what is the difference using stability modes?
Bernhard.F
When I want to set up "Position hold", "Return to home" and "Auto landing" I read that I should activate the Stabi Mode Coaxial also.
Is it really needed
What is the difference in using the stability normal and the coaxial mode. I found no description regarding the difference in behaviour and if it is really needed.
Best Regards
Bernhard
you can see it all in manual here:
http://manual.spirit-system.com/index.p ... n_(Normal)
http://manual.spirit-system.com/index.p ... ion_(Acro)
http://manual.spirit-system.com/index.php?title=Coaxial
And here is short description:
http://manual.spirit-system.com/index.p ... #STABI_TAB
If you engage GeoLink functions directly by channel then it does not matter what is configured as Stabi Function.
On the other hand it is not that hard to just try the funciton in the air. You can use momentary switch to make it perfectly safe.
Bernhard.F
Thank a lot for the fast answer! It helps me for configuration in advance.
