Hi Thomas,
using now the Geolink and the Return to Start, I can define in the software a minimum hight.
But depending where I'm flying, the environment conditions are different.
At my model Airport 10m would be enough, but closer to my home there are houses and 30m minimum hight would be needed.
Considering that the hight consumes power, it would be appriciated that I can set up the transmitter with the minimum hight with a separate channel, similar to the tail gyro.
0-100% means:
0%-X% = Minimum hight off
X% - 100% = Hight from Xm hight minimum can be defined with the existing parameter in the geolink software up to 100m separate via channel.
Then I'm able to define the RTH minimum hight depending on the conditions with battery minimum consumption. Safety is given by the minimum hight as well, in my case 10m.
Best Regards
Bernhard
Geolink: RHT minimum hight via transmitter and chanel
Bernhard.F
Hi jjuk,
this is totally clear, as well when you set the parameter to zero. But what I'm asking ist to be flexible depending on the area where you are. Because Helicopter have not so big batteries and if it is close to the end than energy saving is needed. So why go to 30m if there is around no tree or house? But if you fly somewhere you have objects around like buildings, then it is a good idea to go as high as necessary in that area. If I can decide the hight, I can adjust it before flying. So, it is not possible, neither higher nor lower. This is what Im asking for, to be able to adjust the minimum hight, if I want.
Best Regards
Bernhard
Best Regards
Bernhard
