Hello Tomas,
I would like to adjust the cyclic head sensitivity with a rotary potentiometer from the transmitter for the three banks. I have selected the "P: Cyclic sensitivity" function in the channel display and channel 9. I have created a transmitter with this potentiometer on the jeti transmitter and put this encoder on channel 9 when assigning the servo.
In the channel selection in the Spirit menu of the transmitter, I can clearly see that when the potentiometer is activated, channel 9 reacts between 20-100, in the middle it has exactly 60, as is currently set in the Sensors tab. But when I turn the potentiometer it changes the value in the sensor display does not change and remains at 60.
What am I doing wrong or am I misunderstanding this P:cyclic sensitivity function? Or is it not intended that the cyclic head sensitivity can be set in this way?
Please help.
P:Zyklische Empfindlichkeit
it is enough to close the software.
When software is open the value will not change.
Yes, it is same.
