Hi guys,
I have spirit on my goblin 700 (original v1) and my rescue set to normal with 70% collective. I got a boom strike (the blade took a good chunk of paint from the boom) yesterday when testing the rescue function from inverted hover position. Is there a way to make rescue flip less aggressive?
How to make rescue less aggressive?
wow, that sounds bad.
You can make it less agressive by decreasing Aileron/Elevator range and decreasing Collective pitch for the rescue, in your case aileron/elevator is probably too big. What angle can you achieve on the full stick deflection?
Well, you can decrease Collective pitch for the rescue first to for example 40%. If you have small camera, I recommend to record tail boom during the activation.
Then you will see if it is too close or you can increase.
