Built-in telemetry variables
Scott H
I have Spirit, Spirit Pro and Spirit GTR (haven't used the GTR yet).
In the Jeti (DS-12), under Timers/sensors and then sensors/logging; I see S Vibes and S RPM - Am I correct that they are telemetry values from Spirit?
I want also Battery Voltage as a telemetry variable - will the GTR have that? is there any other way beside adding an MUI or unisense, or related add-on?
Yes, S xx values are telemetry values from Spirit units.
For voltage values and similar, you have to use a MUI sensor or a speed controller that has telemetry (and you either send it to the Spirit unit or to the Jeti receiver to the EXT port), the instructions are here:
http://manual.spirit-system.com/index.p ... _telemetry
Scott H
Thank you for your reply. I should have mentioned, this is a gasser heli (no esc). Still, the approach is the same. I need a MUI or equivalent.
Regards,
For glow or gasoline engines, either the voltage indicator of the receiver in the radio is enough to monitor the on-board battery, or to monitor multiple batteries, e.g.:
http://support.jetimodel.cz/en/katalog/ ... kt/MU3-EX/
RPM sensor:
http://support.jetimodel.cz/en/katalog/ ... M-HALL-EX/
http://support.jetimodel.cz/en/katalog/ ... t/MRPM-EX/
other:
http://support.jetimodel.cz/en/katalog/ ... 2-G800-EX/
