Second spektrum sat wiring question
Eddie52
Can the second sat be connected thru y harness to the aux port along with my throttle cable? Or must it only be connected thru y harness to the rudder port with bec. The reason I would prefer the aux port is that my bec wire is heavy guage and I cant seem to find a heavy guage y harness so I would prefer to connect it alone to rud port. And use y harness an aux port.
you can use this Y-harness:
http://www.conrad.com/ce/de/product/208 ... bel-050-mm
You have to connect satellite to RUD port and Throttle (ESC) to AUX port, but you can use Y-harness in both AUX and RUD ports.
Alternatively you can use full size receiver so it can be connected without any additional cable.
Eddie52
Thanks for the quick response. That cable looks like it would work perfectly.
