[ Version 3.4.2 released! ]
New version 3.4.2 released!
  • Updated GeoLink Altitude Limit:
    • Altitude Limit has configurable triggering Altitude in flight.
    • Altitude for Triggering can be now configured in two ways:
      • [NEW from 3.4.1] Defined by Altitude at which the function is engaged
      • [NEW from 3.4.2] Defined by channel value - from channel value between -100% - 0% triggering altitude is calculated. You can see calculated value in the GeoLink window - Aid tab.
  • Updated GeoLink functions:
    • GeoLink functions such as Return to Home, Geo-fence, Position Hold will be more smooth.
  • Updated GeoLink Vertical Correction Gain:
    • GeoLink Vertical Correction Gain can be configured from 1 to 150.
  • ESC telemetry - Kontronik was deprecated:
    • This telemetry option is no longer working with Spirit v1.
    • Please use TelMe telemetry option instead.
  • New GeoLink firmware updating:
    • All GeoLink modules can be updated easily directly from the Spirit Settings without downloading any file.
    • Firmware can be selected from the List and then you can press the Flash button.
  • New GeoLink v2 firmware 1.3.1:
    • Improved operational stability of the GeoLink when flying.
    • In rare cases communication was interrupted. All should be fine now.
  • Updated Rudder Control Type - Motor:
    • All Spirit units received support for Tail Motor.
    • You can select Tail Motor support in the Expert Settings or in the Setup Wizard.
  • Updated Governor:
    • Support for new Goblin RAW 420.
    • Sensing Divider has range up to 32.
Update for the Spirit units, GeoLink v2 is available in our Download section.
WARNING: Please be aware that GeoLink's function Altitude Limit behavior has changed and Return Altitude parameter need to be configured.
