Fw 3.42 Pitch Range
nichtdiemama
Hello
Is there an change in the pitch range setting. I have an Heli with the FW3.41 and had to the the pitch range only ones. It was the same for every bank. Today i updated my Protos to the 3.42 did the settings and went flying. Everything was okay until i switched the bank from 0 to 1. Instantly the Heli fell down because the pitch didn’t work. I just managed to switch back and landed safely. Back at home i saw that you have to set the pitch range for every bank directly. The standard value was 64 (way to low). Is this new?
