Spirit GT Kontronik Kolibri RB1C missing in telemetry
madman
Hi there,
I got everything working after long searches ;) and the telemetry data from my Kontronik Kolibri 140 ESC is transmitted through the Spirit GT to my FrSky receiver and Radiomaster TX. Everything but the consumed capacity. Is there a known problem, that this value is not transmitted? Using S.Port I get the value from the ESC direct to the RX, but I don‘t like to have two more cables and a y-connector.
I get RB1V, GAlt, Fuel/Vibration, RB2C and a lot more, but RB1C always stays at 0, although the TX shows, that it regularly receives a signal.
Any ideas?
Thanks,
Oliver
have you tried it in the air or without blades on the bench?
madman
Without blades on the bench.
Then please try it in the air, it will very likely work well.
madman
Thanks, will do that and report back.
madman
Works as you said - no problem at all, just on the bench.
Thanks for the help!
Solved!
