Beginner and Advanced mode in software
Dr.Fleming
I understood very well that a lot of Flying friends not have the money it wish to buy big Transmitters ect.
But I thing it will be a good idea, to have an option on the software when it start the first Setup, , that the user can chosse,
" Full Channel ability" and a other option " Not enough channel available" ! Like the minus setup channel over the Gyro gain ect.
That for the standard user will Help a lot and clarify the main and the Function of the software.
To remember the " Servo Travel correction " option window tab (that cost me nearly a year waste of times and Test's!),
ok this is a fantastic option, but only for user he cannot spend for three same Servos on the swaplate,
for a normal user when he touch this, he get in big problems!! :?
ZeXx86 wrote:It cant be programmed for same function, but you can combine it together when you have only few channels. System is always doing what is programmed. Unfortunately if there is some misunderstanding and you do not check it on the bench then you can think it is doing something wrong.
